oil pressure question
Old Apr 1, 2011 | 09:01 PM
carterbrad94's Avatar
Default oil pressure question
3.4 my oil pressure dropped to the line above the red line when i was cruising in 5th drop it in 4th it was half way mark sel light came on also got to the house an looked around it is leaking around the oil pan an front seal i have not had it presser tested yet and not sure about the oil sending unit
Old Apr 1, 2011 | 10:30 PM
Is there are question in there or are you just letting us know?
Old Apr 1, 2011 | 10:33 PM
if its leaking oil that makes the oil pressure drop right o an im 1 an a half quarts low
Old Apr 1, 2011 | 11:54 PM
No, an oil leak doesn't directly make the oil pressure drop (oil pressure is not crankcase pressure). But a bad enough leak to where the level in the pan is so low that the oil pump starves out will give you low, or no oil pressure.
Old Apr 2, 2011 | 01:52 AM
ok well monday im going to my brothers shop to have him pressure check it
JPrice
Apr 27, 2013 04:00 PM
BenL07
Jul 21, 2011 12:44 PM
OldschoolZ
Dec 17, 2010 10:02 PM
ryan88z
Mar 1, 2010 09:26 PM
azmattaz06
Jul 27, 2009 07:49 PM
