Oil pressure high
Step one should be check your pressure with a good hand help gage. It is possible that if you ran low oil pressure for a long time your pressure reliel valve got stuck. Possible but very unlikely.
Why replace a sensor if it is reporting right. You could reinstall your old sensor just to see what it gives you.
I installed a low miles 2002 3800 in my my 96. She has reads between 1/2 and 3/4 since day one. She is a little higher on cold mornings and a little lower on really hot day. I would expect the pressure to rise a little if I installed a new pump.
FYI factory gages are known for being inaccurate. That is why they do not put numbers on them.
Gorn, his pressure is fluctuating between 90 psi (3/4 mark) and 105 psi. Is it still safe to assume his pressure switch is reporting right?
#20
I dont normally down talk my competitor's products but with Duralast parts they seem to be of a lower quality than my store's Master brands. If you are a big fan of AZ get their Standard brand or something from BWD. (Neihoff is BWD and just as good). I get quite a few customers in my store that have had bad luck with Duralast parts. Not all AZ parts are crap but it does seem that their store brand stuff is.
Massey
Massey
