Oil Pressure
What would cause my Oil Pressure Sending Unit to blow out at the top? Whenever my maro is started cold, its usually at the 80 mark and when driving it drops to about 40-60.
95 3.4L
Jordan
95 3.4L
Jordan
Ouch! put a mechanical pressure guage on it to see what the true reading is. I think there is a oil pressure relief valvu/spring that can sometimes get stuck or you could have possibly bought a defective one.
what kind of oil filter are you using. 80 is as high as the gage goes so it could be more. i would think a sensor would be good to a fairly high psi so im thinking it would take more than 80 psi to blow out the top. someone could have put the wrong spring in the oil pump or you could have some kind of blockage in the oil system
Yah, it's always been like that. After letting it warm up a bit, it drops to mid gauge.
