Oil
Old Jan 16, 2008 | 11:28 AM
3.4CamaroCDOG's Avatar
Default Oil
Does not having a full level of oil effect ur cars performance cause i needed some and i put it in my car this morning and got to a stop sign and flowwed it and my rear spinned all the way around and it wasnt even wet outside has anyone else experienced this?
Old Jan 16, 2008 | 12:52 PM
bluovlh8er's Avatar
Default RE: Oil
no, and can you please put oil in ur car
Old Jan 16, 2008 | 03:08 PM
Default RE: Oil
Sounds like the oil was put on the tires. LOL
Low oil level does not affect power, except when it goes low enough and the engine seizes, and then there is no power. Too much oil willlower power if the level is high enough for the crankshaft to touch the oil and create unwanted extra drag.
Old Jan 16, 2008 | 06:02 PM
Default RE: Oil
If you flowwed it and got your rear to be spinned around on "dry" pavement with a V-6, I would say that the road was frosted right where you sitted. And yes, I have experienced that too!
Old Feb 11, 2008 | 08:26 PM
importmd's Avatar
Default RE: Oil
you were low on oil so you beat on it? keep up the good work
Old Feb 12, 2008 | 12:08 AM
skylinrcr01's Avatar
Default RE: Oil
sounds like the plasma phaser is misalligned. try recomboobalating it.
Old Feb 13, 2008 | 08:33 AM
likearock91288's Avatar
Default RE: Oil
"sounds like the plasma phaser is misalligned. try recomboobalating it. "
NICE.
i've experienced throwing a 3.8L camaro rear around on dry pavement, with the help of a jeep on the passenger side.
a 3.4L might need more like a tahoe or suburban to do it.
