Oh My! Got my codes read....
So I am just back from auto zone. Wanted to get my codes read before I invest into new plugs and wires just to make sure that is what I need. The reason I didn't do this earlier is because my SES light never came on. Aparantly that is broken too, because with the codes that I've got it should have been lit at all times.
So here it goes: P0102: MAF sensor P0175: Running rich P0300: Random misfire detected P1280: Transmission component slippage then another P1280 (but with weir symbols in the corner). So yea, changing out plugs shouldn't hurt but now I am wondering will it improve anything? The misifre might be a result of a bad MAF sensor too, right? That could also cause the engine to run rich. So I will need to check that, but I don't know how. Then I have the damn transmission problem. I think that is the most likely cause for the shaking and shuddering I was whinning about earlier but I have no idea what will be required to fix it. I just checked my transmission fluid level and it is good. Any help on where should I start approaching this? I am actually thinking that it would be cheaper to take it to a mechanic to fix everything at once than to go through different possible interpretations for the causes of the codes with trial and error, and waste money on replacing perfectly fine parts. [:'(] |
RE: Oh My! Got my codes read....
Looking at your avatar, I am assuming you have 3.8 motor. I would change the MAF sensor first. They are known to go bad. Easy to swap out. Here is a picture showing location.
http://www.autozone.com/images/cds/g...3d801ceba4.gif |
its not so bad you just need a maf and tranny lol.
You can pull the wiring connector off the MAF sensor & disable it. The engine will now run under the control of the MAP sensor (speed density mode). If it runs better with the MAF disabled you can assume the MAF is bad or dirty.
ORIGINAL: z28pete You can pull the wiring connector off the MAF sensor & disable it. The engine will now run under the control of the MAP sensor (speed density mode). If it runs better with the MAF disabled you can assume the MAF is bad or dirty. |
anyone have a new EGR valve they wanna sell?
ORIGINAL: z28pete You can pull the wiring connector off the MAF sensor & disable it. The engine will now run under the control of the MAP sensor (speed density mode). If it runs better with the MAF disabled you can assume the MAF is bad or dirty. And what about my transmission problem. The liquid appeared brown when i checked it. Should I bother replacing it, or is my entire tranny doomed already? |
Unplugging the MAF may run just the slightest bit different. Should be close to normal.
i got hte same code u did.. p0300. and my problem was the EGR valve.
hey armynatguard18 i just replaced mine. my old one isnt good but i bought a used one for 80 bucks. not bad compared to the new onew that cost a lil ove 200..pm me if u need one might be able to hook u up |
ORIGINAL: maroman209 i got hte same code u did.. p0300. and my problem was the EGR valve. hey armynatguard18 i just replaced mine. my old one isnt good but i bought a used one for 80 bucks. not bad compared to the new onew that cost a lil ove 200..pm me if u need one might be able to hook u up EDIT: never mind, i found it in the diagram above. :D |
