OBD1 code 36
Old Feb 15, 2010 | 06:00 PM
libertyforall1776's Avatar
Depending on how bad it is, you may need to replace the section of damaged wire.
Originally Posted by thetal1
Not spark plug but the actual wires that plug into the coil pack.
I'm using my phone right now so when I get home ill go through everything.
Old Feb 15, 2010 | 06:23 PM
thetal1's Avatar
its really not that bad.
i replaced the crankshaft sensor on the front of the engine should i just go replace the other one on the side?
or just go to the camshaft sensor?
Craby what book do you have cuz i have a haynes and its not in there?
Old Feb 15, 2010 | 07:01 PM
the dtc 36 does not refer to it on the 93 but there isnt one on a 93 so it could be it. dont know. do u have a second crank sensor on the side of the block?
Old Feb 15, 2010 | 10:21 PM
thetal1's Avatar
on the pic the liberty posted its num. 25.
it says it refers to the 3x signal (which i think im not getting from what the diognostic tool says)
Old Feb 15, 2010 | 10:50 PM
right then if u have one check the wires to it and if they look good change the sensor.
Old Feb 15, 2010 | 10:54 PM
thetal1's Avatar
so replace the other crankshaft sensor before the cam?
it says it goes with 3x signal error and i dont get 3x its says 24x. (just trying to make sure)
Old Feb 15, 2010 | 11:28 PM
im confused. lol. u need to look under the car and see if u have a crank sensor in the location shown on the pic liberty posted. i think... anyways if the 3x is bad it would be giving bad numbers for the 24x to the computer.... if thats what u have. sorry man i dont have any info on a 95 so im trying to think it out.
Old Feb 15, 2010 | 11:46 PM
thetal1's Avatar
I know there is one on the front cuz i replaced it. As for the side I am not sure ill look but I'm thinking its gonna be hard to see.(i looked and i think i saw it but i didnt jack up my car so tomorrow ill look)
So your saying both would work together and if ones bad it might cause the other to throw a code?
I'm just trying to be thorough cuz I don't want to go completely through the car. Also I don't wanna take it to a place where they will charge me to have them tell me what I know already.
Old Feb 16, 2010 | 12:49 AM
well thats if the 24x is working correctly. at least thats the way i am understanding it. if u want to make sure u will need to go threw the testing procedure for the 24x and the 3x. u need to get a factory service manual. wow yours is kinda spendy. at least the set i found is. three book set.
http://cgi.ebay.com/ebaymotors/1995-...#ht_1994wt_773
Old Feb 16, 2010 | 01:02 AM
  #20
thetal1's Avatar
yeah there is one on craigslist for 90. im gonna do some more research. this is killing me
