Notice SOP Alum. Driveshaft upgrade difference?
Old 10-28-2010, 12:29 PM
evilkal's Avatar
I have a little bit around 3200 RPMs when I'm giving it hell. But it just kinda sounds and feels like it's revving with my exhaust. In normal driving, I have never noticed a difference.
And even accounting for the stationary mount, it's not gonna be 15 lbs worth of weight. You're still losing a good bit of mass(Probably 15 pounds?) by going to the aluminum DS.
Old 10-28-2010, 04:26 PM
The aluminum drive shaft does not add any power, but being lighter it takes less power to spin it up so it should help acceleration. The fatter the rear end ratio the more noticeable the effect. However, once it reaches a steady speed the power at the rear wheels will be the same. Get a similar effect by going to an aluminum flywheel.
Old 10-28-2010, 05:19 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I went from the stock 2 peice in my v6 to a one peice alum from a 99 ss. I think it helped a lot.
Old 10-28-2010, 05:23 PM
evilkal's Avatar
How come people never believe me when I say that stuff? And when I do, they don't understand it... WTF man lol
Old 10-28-2010, 11:31 PM
Since the purpose of the two piece shaft was for V6 engine vibration dampening, has anybody who switched over to a one piece shaft noticed a difference?
I always wondered why GM went through all that complication. Good to know.
Old 10-30-2010, 07:12 PM
libertyforall1776's Avatar
Interesting:
http://www.ws6.com/mod-1.htm
Old 10-30-2010, 07:17 PM
^ For a one-piece to one-piece swap, definitely not worth the cost then if the hope of a performance gain is the only reason for doing it.
Old 10-30-2010, 07:59 PM
mbar's Avatar
i have a 95 v6 and plan to swap my 2piece for a steel 1piece since i picked it up for $30 and only have to buy new ujoints
Old 10-31-2010, 08:51 AM
evilkal's Avatar
Yeah if you already have a one piece steel, there's no point in getting an aluminum driveshaft unless you just really wanna save that 5 extra pounds haha.
  #20
Old 10-31-2010, 08:34 PM
tripwire1124's Avatar
yeah i went from a 2 piece to a one piece....ill recommend them.
bbcamaro28
04-15-2014 08:34 AM
scott vt 0628
05-29-2007 12:07 PM
mofo123
11-01-2005 11:39 PM
Quick Reply: Notice SOP Alum. Driveshaft upgrade difference?
