Not Starting: 97 3800 5-Speed
Old Jul 26, 2011 | 09:40 PM
  #21
BasicConcepts's Avatar
Technical User
Ya the highbeam switch is actually by your feet
Old Jul 27, 2011 | 11:12 AM
  #22
ZZ04's Avatar
I got everything taken apart now and upon removing the lock cylinder, I found one of the wires going to the key reader in the cylinder was cut.
Its cut in a location where I think I might be able to repair it.
My question is would using a but connector to do the repair alter the resistance measured at the key significantly? Basicly, would it be better to use a but connector, or just do a straight splice?
Thanks!
Old Jul 27, 2011 | 11:43 AM
  #23
Thanks!
Straight splice with solder and heat shrink. Do not use a connector. You can not crimp them good enough and they will build resistance over time. Use a butane solder gun. Electric one could damage the electronics.
Old Jul 27, 2011 | 02:40 PM
  #24
ZZ04's Avatar
Thanks for that info. I'm curious to know, however, how an electric soldering iron could damage the electronics.
I actually plan on removing the cylinder and its wiring completely from the car so I can perform the work on a bench rather than in the car.
I have access to an electric soldering iron but not a butane one. I'd just like to know, this way I can proceed properly.
Thanks in advance!
Old Jul 27, 2011 | 02:53 PM
  #25
GM made all of us switch over to butane in the early 80's. They said it could damage the electronic with static spikes. I think the biggest issue is when it is turned off but I am not sure of that.
Old Jul 27, 2011 | 05:15 PM
  #26
ZZ04's Avatar
Is it the solder itself that causes the problem?
Old Jul 28, 2011 | 05:17 PM
  #27
ZZ04's Avatar
I've soldered it up now and covered it with heat shrink tube. I'm going to wrap it with some electrical tape and put everything back together. If everything goes well the car should be running by the weekend.
Old Aug 4, 2011 | 05:16 PM
  #28
ZZ04's Avatar
UPDATE: When trying to reinstall the ignition cylinder, the wire I had soldered broke again. At this point I decided to replace the cylinder all together. I ordered a new one from rock auto.
I installed it this morning and the car runs now. Thanks for all the help everyone!
th3fr4nchi5e
Sep 12, 2014 09:26 PM
Krusher RS
Jul 21, 2013 12:56 PM
beer4me
Mar 4, 2010 05:22 AM
rjrhino1
Feb 25, 2008 10:54 PM
01camaro.dude09
Jun 20, 2007 11:11 PM
