no start
Old 01-14-2014 | 09:05 AM
camaroteen82's Avatar
Exclamation no start
been having a few issues with the radio so I removed the bcm never got around to soldering the points on it and put it back in the car and now it won't start. is there something I need to do to reset something so it'll start?
Old 01-14-2014 | 12:20 PM
nevermind. dad left the car in 5th and since I usually leave it in neutral and start it without pushing the clutch in it didn't start. fired up when I pushed the clutch pedal in.
Old 01-14-2014 | 06:29 PM
dont do that,,, lol.
Old 01-17-2014 | 12:36 PM
well when I did that nothing happened so I thought something was seriously wrong lol.
Old 01-17-2014 | 01:53 PM
Well that's interesting, since the neutral safety switch for a manual trans is operated by the clutch pedal. You shouldn't be able to start the engine while in any gear (or neutral), until the clutch pedal is depressed.
Perhaps yours is malfunctioning: 1987-02 Neutral Safety Switch w/manual trans
Old 01-17-2014 | 02:18 PM
I was so going to post this
Something is not right, The clutch must be pushed in to start the car and how would the system even know what gear it was in? There is no gear sensor I am aware of except reverse that that just turns on the lights. Your car would have to have a neutral sensor in the shifter?
Old 01-17-2014 | 02:38 PM
Yeah, I thought of that too. But how could that make current from the ignition switch magically jump across the open clutch pedal safety switch? We know he has a clutch switch, it worked for him.
Old 01-17-2014 | 03:46 PM
you guys crack me up.
Old 01-17-2014 | 05:21 PM
The only reason I was slow posting was I wanted to make a sanity check and I tried my car. After I tried I thought to myself, I am a moron for even trying it.
I think my 74 would start in neutral but then again it would try to start in any gear as long as the seat belt was buckled. LOL
Old 01-17-2014 | 05:35 PM
So, how did your "sanity check" work out? Whatever brain cells that are left still functioning alright? lol
