newb need your help!
Old 06-14-2007, 09:24 AM
desi's Avatar
Default RE: newb need your help!
For the cyl 1 misfire code, swap the coil pack for that cyclinder pack with another one. If the code changes to another cylinder, you have a faulty coil pack. You can pick another one up from a junk yard dirt cheap. They are known to go bad, specially if there is any moisture present.
Fix the tranny mount
Connect all vaccum hoses properly
Track and fix the misfire
Change plugs, wires and oil/air filter
Run the car for a while before replacing O2 sensor. That code may disappear...
Good Luck
Chrisd0729
08-25-2011 10:20 AM
termn8r
05-29-2010 07:29 PM
spotya1
10-15-2008 05:20 PM
ph0enix
01-03-2008 10:03 PM
Clod_Z28
11-28-2007 12:39 PM
Quick Reply: newb need your help!
