New egr fails?
Old May 11, 2010 | 02:30 PM
JordanN's Avatar
Default New egr fails?
I just replaced my EGR valve today and cleared all the codes. At times, it wants to work, but at others, it wants to act like it did before it was replaced. If I have the gas pedal down a bit, it'll stumble, but if I gently lift up, it'll be fine. The design on it is somewhat different.
New one
Old one
EGR 2 & 3 Solenoid Failure.
Any ideas?
Old May 11, 2010 | 03:31 PM
Did you replace the solenoids or just the EGR valve? The code is complaining about the solenoids not working, it says nothing about the valve. So if you just replaced the valve, the problem will still be there.
Old May 11, 2010 | 04:03 PM
JordanN's Avatar
I've gone through tons of Google pages and could not find a single picture of a 3.4L Camaro EGR solenoid. Where is it located? Also, if its the solenoids aren't part of the valve, how come I can't find them at autozone, oriellys, advanced autoparts etc?
Old May 11, 2010 | 04:41 PM
libertyforall1776's Avatar
EGR Delete time?! ;-)
Old May 14, 2010 | 04:07 AM
BasicConcepts's Avatar
Technical User
what gauge steel should i cut a delete plat out of for my 95 3.4
Old May 14, 2010 | 05:25 AM
JordanN's Avatar
You can get a delete plate for around $10 from Oriellys I think or Autozone.
Old May 14, 2010 | 01:19 PM
Technical User
just checked the websites for autozone oriellys advance no plate avail
Old May 14, 2010 | 07:57 PM
JordanN's Avatar
Well, try Summit. I know I have def seen something in there.
Old May 14, 2010 | 10:11 PM
Technical User
well i can easly cut a piece of steel i just need to know how thick it should be with out overdoing it
Old May 20, 2010 | 01:48 PM
JordanN's Avatar
Well, took egr off and ran the car to see if any carbon was coming out, no. Could it be to much back pressure causing it to fail? Cause if I hit the gas just right, I can make it backfire. Or could it be a clogged cat?
Jordan
