need help replacing front turn signal light
Old Aug 25, 2007 | 03:00 PM
Yankee2441's Avatar
Default need help replacing front turn signal light
i just bought a new bulb for my 2001 camaro to replace the turn signal light the blew out in the front (driver's side). it's a pain in the *** trying to get at it to replace the bulb and nearly impossible to stick your hand down in doing so. does anyone have any recommendations on the best way of going about replacing it? thanks.
Old Aug 25, 2007 | 03:10 PM
02StanGT's Avatar
Default RE: need help replacing front turn signal light
Have you tried getting at it from the bottom? That seems to be the easiest.
Old Aug 25, 2007 | 11:33 PM
Yankee2441's Avatar
yea that's exactly what i had to do, but thanks
Old Aug 29, 2007 | 10:36 AM
silverbullit's Avatar
Best way is to remove entire headlight assembly. There is a 10 mm bolt that holds it in place on top. Remove this and carefully remove the entire housing. Takes some patience but thats the way I did it.
Old Aug 29, 2007 | 02:53 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
i had to do mine three times heres how i do it in 10 mins or so get under the car remove the plasic under guard reach up into the head light area un clip the little plasic peice that holds you signal bulb inplace put the new bulb in click it back in and put everything back and your done
Old Aug 29, 2007 | 06:09 PM
01 Camaro Cp's Avatar
I too pop the headlight assmy out. Remove the bolt as Silverbullit said, and the assembly slides toward the center of the car (right moves left and left unit to the right). You do it right, you don't even mess up the headlight aim.
I'm a little to big to slide under the car with out jacking it up and this method works well.
pcarollo
May 21, 2015 02:50 PM
lawboy19
Sep 13, 2011 08:32 AM
tomstheman86
Aug 31, 2010 06:59 PM
Andrew*B
Jun 27, 2008 11:35 AM
bill12690
May 30, 2007 12:57 PM
