need help finding this oil leak
Old Nov 7, 2008 | 02:17 PM
domo556's Avatar
Default need help finding this oil leak
Alright i'm leaking oil i changed my oil pan gasket and the valve cover gasket and i'm still leaking oil. Does anyone have any tips? I have a 1994 3.4l
Old Nov 8, 2008 | 01:25 PM
TheGrimReaper73's Avatar
Default RE: need help finding this oil leak
is it leaking from your oil filter? o.0
Old Nov 8, 2008 | 01:28 PM
domo556's Avatar
no i changed that too
Old Nov 8, 2008 | 01:46 PM
eh hm.. im not to good with the oil part.. so im sure some one else might know..
Old Nov 8, 2008 | 05:34 PM
Try looking at your intake manifold valley gaskets (between the heads). You might want to clean the area off as best you can first, then see if you can find an oil trail after driving it. Could be in the back by the firewall where it's hard to spot.
Old Nov 10, 2008 | 12:23 PM
TomS68's Avatar
Could be your rear main seal on a car that old. There's goop you can buy to dump in your oil to get that seal to expand a little and possibly reseal. That may stop your leak. But the only real cure if that is indeed the situation is an engine rebuild. But if it's not the oil pan, it's not the valve cover, or intake gaskets and you're still seeing oil, then it's likely the mainseal in back of the block.
Thanks,
Tom
Old Nov 10, 2008 | 01:17 PM
1994chevycamaro's Avatar
could be the oil pan its self i have the same prob on same year car and motor, where do you live at do you have a lot of salt and does the leak stop at a certain point?
_night_stalker_
May 13, 2011 05:51 PM
justintr1990
May 7, 2007 12:17 AM
o2camaross
Mar 24, 2007 12:08 AM
68tubb
Oct 19, 2006 09:55 PM
