need help with camaro 3.4 anyone with same engine ???
Old Aug 21, 2012 | 03:32 PM
juan_leal1992's Avatar
Smile need help with camaro 3.4 anyone with same engine ???
ok so basically i bought a 3.4 and the guy really did a number on it, all of the vacuum lines on top of the intake manifold were misplaced so i had to buy new ones. i got them in through mail today everything is correct i followed the diagram however i cant figure out where this last line connects to here is the line Name:  IMG_20120821_131014-1.jpg
it is connected to the brake booster valve on the diagram here it says to connect it to acsry Name:  Untitled-1.png
but what is acsry?? i dont know where or what that is ? i have no loose lines i can connect it to? right now i have the line shut with a screw so no air is coming out but am i suposed to connect it to something ? or just leave it like that .
Old Aug 21, 2012 | 03:38 PM
BasicConcepts's Avatar
Technical User
acsry is your heater box thats what controls the blend door. as for the line with a bolt in it that defiantly isnt right, i can tell that its near the fuel lines but cant quite remember where it would go (i havent had a 3.4 in like 2 years) it looks like a pcv valve but thats not where the pcv goes.
Old Aug 21, 2012 | 05:16 PM
1augapfel's Avatar
I rebuilt the 3.4 in my 94 a couple of years ago. This pic help?
Attached Thumbnails need help with camaro 3.4 anyone with same engine ???-p9220010.jpg
Old Aug 21, 2012 | 05:22 PM
i cant see the when i click on it it says i dont have permission
Old Aug 21, 2012 | 05:26 PM
Technical User
thats what i thought it was. theres a T fitting that goes into the intake one side goes to the brake booster the other goes to the heater box. the line for the heater box is inside a loom of wires on the passenger side of the car.
Old Aug 21, 2012 | 06:13 PM
thats exzatcly how mines looks, so im supposed to connect that to the heater box??? am i supposed to run another vaccum line? because their nothing close to it that looks like it could be it
Old Aug 21, 2012 | 06:16 PM
Technical User
no there should be a line somewhere in that area (unless it was broken or removed) again its in a loom so it may be hiding
Old Aug 21, 2012 | 06:22 PM
I think the previous owner removed it, i will check it out once im off work and update on progress.....thank you for the help
Old Aug 21, 2012 | 10:01 PM
nope, still nothing i checked very well and could not find any vacuum line to connect it to
Old Aug 22, 2012 | 12:28 AM
never mind found it ! it was exactly where you said it would be, "in a loom of wires" i was mad and ripped open a small piece of the loom and their you have it a small vacuum line! thank you for the help
