My car is idling High
My 3.4l is idling higher than usual, but sometimes it idles higher than other times... When I crunk my car up yesterday it idled around 1200, today it idled around 800 and just now it idle around 2000rpm. I don't know why, maybe you guys can help? It runs smoothly, no lost in power what so ever.
Nope, I live and good ol' FL... Its perfect outside, excluding the rain. But I know that isn't a factor because It was idling high yesterday when there wasn't a cloud in the sky.
My 93 v6 was doing this as well. It was varying between 800 and 2000, sometimes 3500rpm, depending on its temperature. The warmer the engine, the better it idled.
Try checking your oxygen sensors. I just replaced my burned out o2 sensor, and it's idling much better.
Also, has your check engine light been coming on? You might be able to read the code with a code reader to see if that can help you pinpoint the issue.
