multiple missfire 1999 3.8l fuel pressure 40 lbs
Old May 16, 2011 | 09:22 PM
walker61's Avatar
Default multiple missfire 1999 3.8l fuel pressure 40 lbs
Car suddenly develope a multiple misfire. coils good< coil module good< SPARK PLUGS AND WIRE GOOD> replaced fuel filter and the old was not pluged. pump primes when key tuns on. Fuel pressure reads 40lbs and then drops to 38lbs. Could it be the fule pump geting weak
Old May 17, 2011 | 12:47 AM
carguy68ssrs's Avatar
You get a check engine light with that?? The v6 in my s10 had misfire code and it was cam sensor inside distributor
Old May 17, 2011 | 02:31 AM
walker61's Avatar
I got a flashing check engine light and a p300 error code. I checked the cam saft sensor and it was okay.
Old May 17, 2011 | 10:18 AM
DTC P0300 indicates multiple random misfires. This type of misfire is usually caused by a lean fuel mixture. What procedure did you use to check the fuel pressure? The numbers you got show fuel pressure below spec. Have you tested the pressure regulator?
Old May 17, 2011 | 11:00 AM
walker61's Avatar
I used a pressure gausge and attached it to the pressure port on the fule injector rail. The specs call for 48 - 55. I turned the key on but not start, heard the motor prime. I checked the gauge and it read 40 lbs and it dropped to 38 lbs in a couple of minutes. I did not check the regulator. If Imust how do I di it. The coils are not bad on this car. The ignition module tested fine. The cam Shaft sensor tested fine.
Old May 20, 2011 | 10:19 AM
40 PSI is a bit too low and that will cause the fuel mixture to lean out to where the PCM can't correct. It may be time for a new pump or new pressure regulator.
Old May 20, 2011 | 12:29 PM
walker61's Avatar
Thanks pete, I think i will get the pressure gauge out and recheck it by priming 3 or foure times. If the pressure is still 40lbs or higher, i will start the engine and see if it decreses the appropriate amount. Am I on the right tract to check the regulator?
royco95
Aug 2, 2015 10:25 AM
walker61
Nov 29, 2014 11:01 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
lt1z28
Aug 24, 2007 09:48 PM
