Motor is out
Do you have a special tool to remove the main bearing caps? I have mine torn all the way apart except the crank is still sitting in the block. Apparently the mains are pressed in and you have to get a special tool to remove them. I have no idea what that tool is.
Thanks, for the heads up on the main bearing. I still have not got the chance to go back out to the garage and start tearing it down. I was gonna go out there tonight but I am tired an its not going anywhere so it will happen this weekend.
