more questions
is the 94-97 v6's iron block and heads and 98+ aluminum block and heads? also how do you remove that gay speed limiter that kicks in at 118 on a 96 3800? both these questions are bothering me. thanks
The 3.1s have cast iron block and heads. I am not 100% on the 3.8, but I seem to remember the block being cast iron. As for the speed limiter. The speed limiter is part of the PCM software, and can be deleted by tuning the PCM.
www.pcmforless.com is one of the tuners can do it for you.
