maybe u know...
Old Mar 24, 2011 | 06:53 AM
Schappie9's Avatar
Default maybe u know...
99 3.8 I'm looking for the part that the EGR valve bolts on to that has the air tubes that go into ur drivers side exhaust manifold and into intake beside thermostat. Idk what its even called, if ne one knows where I can find one or can post a link.. plz do..
Tks in advance.
Old Mar 24, 2011 | 02:48 PM
Schappie9's Avatar
Maybe u don't know...
Old Mar 24, 2011 | 03:11 PM
3800camaro's Avatar
Massey probably knows and will say somthing when is logs in but until then here's a link the the parts manual. It'll give you the gm part number and you'll have to search a little tho. http://www.z28.com/LyleA/93-02%20%20...s%20Manual.pdf
Old Mar 24, 2011 | 11:16 PM
Massey's Avatar
The part is called an EGR valve adaptor. You can see the one for the 00-02 engine on page 57 item 586. It is not the part for your car but it is what you are looking for. I checked the document for the adaptor for the 99 engine but it was not listed. There is a chance that this is the same part for all 3 versions of this engine.
Massey
Old Mar 25, 2011 | 06:45 AM
Schappie9's Avatar
No its not. The only vehicles are the 95 - 99 Camaro and Firebirds u will find this part on. It's also discontinued from G.M part # 24504960 and after calling dealer, its unavailable. So bone yard hunting I went and came up with none. The only option I think I have is to use the green repair hose that they make for CATs airtube.
So if ever come across one, buy it and lock it away, cuz they r tough to come by.
Old Mar 25, 2011 | 07:34 AM
3800camaro's Avatar
Can you post pics of this part you need?
