Major Door Problems?
I tried two different ways to put these pictures up. I know im not crazy I have done this before. ANYWAYS PLEASE let me know if the pics work and what a possible solution is. ALSO if this fails. The pics are in an album on my CF Page under DOOR. Thanks!
Now the pics work, that helps. For the regulator mounting bolts on the side of the door, it looks like a couple of the slotted holes are alright, but I would still use a large diameter washer to help span any weak area. On the one side hole that is hacked up, I would take a big washer and sand one side of it and the area on the door, then epoxy the washer onto the door. Do that after the regulator is adjusted and the other bolts are tightened down so that bolt will line up. Also do the same washer/epoxy fix with the top fractured holes.
