MAF SENSOR
Old Jan 3, 2008 | 07:34 PM
maroman209's Avatar
Default MAF SENSOR
ok so turned out to be that the problem with my car was the maf sensor... might sound stupid for this one.. but what exactly does this do?? and about how much would it run for one of theses
Old Jan 3, 2008 | 08:27 PM
02StanGT's Avatar
Default RE: MAF SENSOR
It meters how much air is coming into the engine. Used in fuel tables.
As far as cost... It's quite a bit for a new sensor.
http://www.autozone.com/N,15900151//...eResultSet.htm
If it's causing rough engine problems, and it's really the MAF sensor, then you can unplug, and car should run like normal.
Old Jan 3, 2008 | 11:53 PM
aleksandr's Avatar
Mine ran much rougher with it unplugged, especially at start up and idle. Funny thing is that my MAF actually was and still is bad.
You can always try to clean it before you replace it. Use a piece of cloth with some rubbing alcohol on it and carefully clean the wires from any dirty that accumulated there over the years.
Old Jan 4, 2008 | 01:59 AM
02StanGT's Avatar
If you're going to clean the MAF wire, they make some spray cleaner just for that. That way you don't break it on accident.
Old Jan 4, 2008 | 11:18 AM
maroman209's Avatar
would it be bad to run it without the maf????
luky for me im koo with they guy who owns the shop... so hes gonna get a discount for a new one... comparing it to the autozone prices sounds cheap to me... hes gonna get it for 160 i think...
Old Jan 4, 2008 | 06:32 PM
aleksandr's Avatar
ORIGINAL: maroman209
Yea, that's quite a bargain. I'd say the only disadvantages of running a car without a maf should be a reduction in MPG and maybe quicker carbon deposits in the engine and dirtier exhaust due to small imperfections in the air/fuel ratio. I am just making an educated guess here though.
Old Jan 4, 2008 | 07:35 PM
02StanGT's Avatar
Shouldn't be a problem. May not be as accurate, but will work none the less.
Old Jan 13, 2008 | 08:06 AM
97rsturbocamaro's Avatar
when mine went bad i unplugged and it ran just as ****ty, no difference, horrible gas mileage.... go to the junk yard and get one off a 2000 or newer camaro,grand prix,firebird or so on..thats what i did works great! and it was cheapier! i paid $000.00 for mine :-D
Old Jul 28, 2008 | 04:28 PM
pem's Avatar
pem
when this sensor is bad, does it also give bad gas readings?
Old Jul 28, 2008 | 09:03 PM
Chappie99's Avatar
I get bad gas from Tacco Bell.
