ls1 in a 95 camaro?
Old Mar 12, 2009 | 12:42 PM
camaro95guy's Avatar
Default ls1 in a 95 camaro?
I had a question about something for anyone that could answer... I have a 95 camaro that has a 3.4 v6 right now... i have got my hands on a ls1 for very cheap. I know there has to be a lot of things changed... I already have the tranni dirveshaft gas tank kmember and just about all the things i need to swap.. the only thing is i heard the reason the front end of the car was changed in 1998 was because of clearence issues for the ls1??? If any knows about this it would be greatly apperciated if ya could let me know what ya think... thanks a ton
Old Mar 12, 2009 | 01:08 PM
02StanGT's Avatar
I don't think that is the reason they changed the front end. There is a guy on camarov6.com that just swapped an LS1 into his '97. He said it fits just fine. Belows is the short list of things he mentioned you will need. Another link related to your question... http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
Leave fuel system alone, its fine
get ls1 k, steering rack
Suspension is fine, ls1 weighs about the same as the 3.8 believe it or not.
Torque arm mount is different, need ls1
Ls1 radiator, the v6 one only has 1 nipple, ls1 has 2
corvette fuel filter/Reg it has a built in return line as the ls1 rail does not
Obviously exhaust, if you think you current setup will work dont even think about the swap
Trans, again with above, if you have to ask dont try it.
Ls1 harness and pcm, You must modify the wiring to work, took me a week to do.
Some sort of intake elbow, coupler for maf and filter
Ls1 non tcs throttle cable, the v6 one will not work.
Old Mar 12, 2009 | 05:16 PM
Default air box
I also had a question about the clearence in the front of the engine bay. I have been hearing the stock ls1 air box is not going to clear the hood... Would a LT1 air flow set up work with the ls1?
Old Mar 12, 2009 | 07:21 PM
02StanGT's Avatar
Yes. Here is a pic of the guys engine bay.
Old Mar 12, 2009 | 09:01 PM
bluovlh8er's Avatar
the ls1 wont fit in a 93-97, its why they changed the front end. the ls1 is taller
Old Mar 12, 2009 | 10:17 PM
02StanGT's Avatar
H8er, that pic is an LS1 in a 97...
Old Mar 13, 2009 | 07:24 PM
bluovlh8er's Avatar
sorry stan, then why did they change the front ends?
Old Mar 13, 2009 | 07:27 PM
Thanks alot for the pic... I have actually made some friends on car domain that has done the swap and im getting some info from him.... I was alil discouraged about the hole thing when i heard about the clearence issue but now after seeing the pic and talkin to the other guy im more excited than ever... Thanks again.
Old Mar 13, 2009 | 08:32 PM
meteoralp45's Avatar
same reason that mustang changed the look of their car from 98 to 99
Old Mar 15, 2009 | 12:43 AM
MusicMan's Avatar
The Jazz Man
lol, there's no clearance issues. Believe it or not, it's popular for the ls1 guys to swap an lt1 front end. It was just a body style change for looks, not functionality.
