Low Trac Light Blinking
Old 10-09-2005 | 09:30 PM
vhodgesosu's Avatar
Default Low Trac Light Blinking
Okay so my Low Trac Light is blinking and stays blinking long after the car has started. It will go off if I push on the brake and hold it for 3-5 seconds. After releasing the break the low trac light starts blinking again. The ABS INOP light also goes off on with the low trac light. What could be going on here?
Old 10-09-2005 | 10:35 PM
02StanGT's Avatar
Default RE: Low Trac Light Blinking
I have had this happen on my '97 V6. I was stupid and let someone else drive it without me. When I get back in it both lights were on. Come to find out he had ran off the road in the rain somehow. The lights stayed on for a trip to McDonald's were off when I came back outside and started it again. You might try disconnecting your battery, and letting it sit for a while. This should clear them away if it doesn't go away on its own.
Old 10-09-2005 | 11:53 PM
Get the car scanned & see what it is complaining about. Otherwise you will be doing a lot of extra work and buying parts you don't need. You have a computer controlled car and it is trying to tell you something, find out what it is trying to tell you.
Old 10-12-2005 | 03:48 AM
almaster666's Avatar
first unplugg the batery, then scan it if doesnt go away
ive had this problem on a honda, and the problem was that the egr valve was clogged...
i dont know if camaros have an egr valve... ( ? )
Old 10-13-2005 | 05:54 PM
You are having problems with your ABS system and the computer is disabling it to prevent braking problems. Check your brake lites, including the center monted one. If they are burned out they can case the ABS to act up. If the lites are OK, get the car scanned so that you will know what it is complaining about. Once you know what the trouble is, then you can go about fixing it.
Old 08-08-2007 | 04:33 PM
kyleb's Avatar
i seen u can buy a scanner at walmart....i know its walmart but it was like 100 bucks sounds like a decent devise but ive never had one so i dont know...wouldnt it throw you a code the same as a shopswould??
Old 08-11-2007 | 07:22 PM
Skyrunner's Avatar
A scanner from wally world? Get a real scan done on it. If it's the ABS you really want to know about that. Pete is right, get it scanned.
Old 08-12-2007 | 03:56 PM
libertyforall1776's Avatar
Get an Autoxray 6000 if you want a good scanner (I own one):
http://www.autoxray.com/product_detail.php?pid=94
But if you also want ABS testing, a scanner gets more pricey -- you'll need the OTC Nemisys in either case, check eBay, etc.
http://www.nemisysotc.com/
Krusher RS
04-13-2013 10:30 AM
Mikey.
09-19-2010 07:05 PM
Matsbox
05-20-2009 07:40 PM
Nitemare3o5
05-06-2008 08:55 PM
ForgetfulRegrets
08-18-2006 05:39 AM
