lights
Old Oct 12, 2006 | 04:37 PM
airchevy02's Avatar
Default lights
whats up with the lights coming on at night before i evn turn the headlights on... is there a sensor or something? and is there any way to by bass the drls... so there only on when i turn the lights on?
Old Oct 12, 2006 | 05:02 PM
TotalChaos's Avatar
Default RE: lights
yup there is a sensor. it turns the light on after you release the E-brake if it's dark enough.
Old Oct 12, 2006 | 05:29 PM
shnormo's Avatar
Default RE: lights
http://www.lightsout.org/disable.html
On my '99 Z28 the daytime running lights are the parking lights or some
such. If I pull up on the parking brake one notch while the car is
turned off and then start the car, the daytime running lights are
disabled. The DRL's bothered me at first but I just got used to them.
Actually having them on tells other people you have a new F-body since
the older ones (before '98 I believe) didn't have that feature, that's
about the only positive thing I can see for them.
Old Oct 12, 2006 | 06:12 PM
t4nk's Avatar
Default RE: lights
I've got a 97 and its got the parking lights as dtrl's
Old Oct 12, 2006 | 07:03 PM
Camaroguy87's Avatar
Default RE: lights
My '97 always has it's running lights on after I release the e-brake. They turn off after I shut the engine off. But when the engine is off, I can manually turn them on with the switch. I think that's the way it's supposed to be.
Old Oct 12, 2006 | 09:56 PM
uncle bill's Avatar
Default RE: lights
In 2000, GM made automatic headlights standard. I read that somewhere.
Old Jan 12, 2007 | 02:11 AM
suzuki22's Avatar
Default RE: lights
yea i have a 97 and cant get them to go off at night, its really annoying at a drive in or if you dont want to flash someones house, someone once said something about messing with the light sensor under the dash, anyone know anything more about getting them off?
Old Jan 12, 2007 | 02:22 AM
shnormo's Avatar
Default RE: lights
There is a way. I would get a wiring diagram for the switch. Run a new fused wire from the battery to the switch (use a 20 amp fuse 16 guage wire) ad then run it to the input side of your lights. Then for your outputs you can use the stock switch and run new wires to the head lights and running lights to bypass any system.
Old Jan 12, 2007 | 02:23 AM
shnormo's Avatar
Default RE: lights
Also see if your headlights work with the DRL relay in the engine compartment is removed
Old Jan 12, 2007 | 03:34 AM
MadMikeZ28's Avatar
Default RE: lights
There ya go. Remove the module! I have been swapping a 97 engine and harness from an Astro into my moms truck and it has DRL. But they dont come on when I removed the module. And the head lights still work proper. Now mom can drive at night in stealth mode.
Why do they bother you? You cant see them when your in the car driving.
