Light Help ?!?!?
Old Apr 9, 2008 | 11:43 PM
JaySan's Avatar
Default Light Help ?!?!?
ok so its is like 10 o'clock last night and i'm driving and all of a sudden my guages, lights in my air unit , and my fog lights and turn signals are TURN OFF . The only things on are my headlights.Checked my fusesand they look good. What could it be ???[/align]
Old Apr 10, 2008 | 12:25 AM
MusicMan's Avatar
The Jazz Man
Default RE: Light Help ?!?!?
Check the fuses with a multimeter. Sometimes they go bad, and you can't see it. I had that happen in one of my cars.
Old Apr 10, 2008 | 12:37 AM
TomS68's Avatar
Check all your fuses like he said. Also make sure you've got good contact with your negative battery or ground cable. If you lose your ground cable the computer goes beserk and the engine starts to run really rough. You don't mention this but it's obvious you lost a ton all of a sudden. Check the fuses. Also determine which fuse is for the lights specifically that you don't have. Take your multimeter and check to make sure that there is voltage running across the fuse sockets and basically through this method trace back where you lost power from. If there's no voltage in the fuse box period at these sockets then you've lost wiring leading up to the fuse box. Just keep tracking back until you find voltage or fried wiring. It's a treat I know but that's how you find your short or break.
Thanks,
Tom
Old Apr 10, 2008 | 12:47 AM
MusicMan's Avatar
The Jazz Man
Tom has the right plan. Double check your fuses and the block with a multimeter. You can get them at WallyWorld for a few bucks. They aren't profesional grade, but they work fine for stuff like this. It almost sounds like a short happened.
Old Apr 10, 2008 | 06:50 AM
Labyrinth9's Avatar
check your relays too, i had a relay go out adn it killed alot of things like that
Old Apr 10, 2008 | 10:46 PM
JaySan's Avatar
where are my relay switches?
Old Apr 13, 2008 | 01:30 AM
JaySan's Avatar
Wait I think I know the problem . Is there a fuse for my night time lights. because at night my rear tail lights don't work. I changed the bulbs but still no luck
Socom
Nov 9, 2013 01:41 PM
Rent
Apr 22, 2013 11:08 PM
hpd218
Aug 24, 2010 12:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
dustinb
Oct 1, 2007 06:58 PM
