Launch and Shifting Point
Old Sep 5, 2011 | 04:28 PM
BaD ToYz FoR BaD BoYz's Avatar
Default Launch and Shifting Point
Does anyone know bout the best RPMz to launch and shift is...People tell me that i should just letin rev to 6000 Rz but others tell me thats too high im just losing power and wasting time
any input on this
Old Sep 5, 2011 | 05:26 PM
3800camaro's Avatar
depends on your tires. 1500 for street tires, 2000 for drag radials and 2500 for drag slicks. also slowly give it gas dont just stomp on it as you take off. best place to shift at is around 5500 rpm this way you'll hit roughly 4500 in the next gear which is your peak hp point. you'll have to play around with that to get its perfect tho.
Old Sep 5, 2011 | 05:43 PM
old guy's Avatar
any input on this
Curious. V6 or V8? Still stock? Stock gears? Tires? Just wondering.
Old Sep 5, 2011 | 11:05 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I launch at 2200, stock a4, 3.42, and street tires spraying nitrous off the line. 2.0 60'
Old Sep 6, 2011 | 05:29 PM
3800camaro's Avatar
Also what v6 engine do you have? If its a 3.4 then socom is your guy. the 3.8 is alot more torquer then the 3.4 which is why the rpms are a bit lower.
Old Sep 6, 2011 | 05:43 PM
arite thnx for the info...its a v6 5speed stock as a rock...i dump it a like 3000 an get in it easy my tire only bark off the line and they are just street tires
Old Sep 6, 2011 | 05:47 PM
Its Got The 3.8
Old Sep 6, 2011 | 07:09 PM
RFxCamaro's Avatar
You know I always wondered the same thing nice to know.
Old Sep 9, 2011 | 05:50 PM
ok a little off the subject but does anyone know why my i can pull the RPMz up to like 3000 n dump the clutch and the motor just die down then act really weak when i get going
Old Sep 9, 2011 | 06:18 PM
3800camaro's Avatar
Your clutch is most likely slipping. How many miles are on your clutch?
