Keep Breaking transmission mounts
Hey sorry bout the late post guys been rly busy with work but that's pretty funny everybody jumped on da abbreviation lol I meant rear stabilizer bar..or rear strut bar w.e u guys wana call it but yeah like I said I doubt it wld have effect on the tranny insulator/mount...(insulator is the rubber cushing that sits on the actual mount bracket) but yeah no I do not race or dump my clutch or anything crazy I just take it easy like a regular everyday driver..is this a common problem with camaros do you guys change your mounts/insulators every oil change lol seems weird there's gotta be a reason they're breaking so fast other then amazing high quality american materials..lol
if your stabilizer bar is lose, it may be that the extra movement caused by not having it hooked up has worn the bushings in the control arms and banhard bar. if the rearend is moving sideways then it will pull on the mount to the side and up when you take off. worn or lose motor mounts will do the same so check the motor mount bolts and make sure there tight. is the mount lining up when you replace it?
#20
i have not broke one sense i relocated the torque bar mount. http://www.spohn.net/shop/1993-1997-...d-Torque-Arms/
