interior Lights out fuses replaced now and not blowing
Last night driving my 01 camaro i signaled to switch lanes then once in the lane turned off the turn signal at that same instant all of the Dash back lights went out, upon further investigation so did the small lights illumanating the window controls on the door as well as the backlight for the gear select as well as the glove box light.
I checked all of the fuses and replaced the two that were blown:
one was 5 A "IP Dimmer" and another was 20 or 25 A(going from memory) Tail LPS. The fuses have not blown again, however the lights still do not work. Looking for which fuse these interior lights are connected to as well as perhaps a troubleshooting flow chart.
Looking around it seems as the lights are all with the IP dimmer fuse Also everything else is working except these lights, SGS switch works which was also labeled as being tied into this fuse, as well as the back defroster works and its associated orange light when it is being used illuminates. When turning on the insturment lights the LED odometer does dim itself as it should.
Thanks in advance
Ryan
Thanks in advance
Ryan
