Intake leaking antifreze
Old 12-04-2008 | 03:52 PM
Default RE: Intake leaking antifreze
The line looks like the upper to lower gasket. You sure that is where the leak is coming from? Does coolant even flow thru there?
Old 12-04-2008 | 10:22 PM
02StanGT's Avatar
Coolant does flow through from the upper to the lower where the thermostat is, but there should be a rubber o-ring there.
Old 12-05-2008 | 07:05 PM
red94v six's Avatar
So its coming out of that little bubble area? Thats the thermostat housing, and Im not sure if there actually is a gasket, or if its just sealant or even just the o-ring lol. There are gaskets that would fit though.
Old 12-08-2008 | 02:41 PM
maguilar496's Avatar
these are the gaskets that i got when i asked for intake gaskets.
i took the car to a friend and he told me these are the right ones. he also said he has to unbolt the engine and move it a little forward to change them.
Is that true? i thought you could do this with out unbolting the engine.
thanks
http://s227.photobucket.com/albums/d...nt=gaskets.jpg
Old 12-08-2008 | 02:42 PM
Old 12-08-2008 | 03:06 PM
02StanGT's Avatar
Those are intake manifold gaskets. They attach between the head and lower intake manifold. The one I think you want, goes between the upper and lower intake manifold.
Old 12-09-2008 | 08:42 AM
is the one that i need called the plenum gasket?
Old 12-09-2008 | 12:26 PM
02StanGT's Avatar
This is a pic of what we are talking about for the upper to lower manifold gasket. The site the picture came from called it what you did. A plenum gasket.
Old 12-09-2008 | 04:44 PM
thats what i'm talking about.
how can i ever repay you. [sm=alcoholic.gif]
thank's
crimson09
12-15-2018 07:07 AM
carid
Vendor Special Buys
01-20-2015 07:08 AM
twjohnson
12-08-2012 04:23 AM
djs383
03-29-2011 10:37 PM
ssoper89
03-18-2010 12:31 AM
Quick Reply: Intake leaking antifreze
