intake gasket?
intake gasket?
I have a leak on my 96 camaro 3.8 and from what I see it looks like it is coming from the intake gasket just above the water pump area. Do the camaros have the plastic elbow piece that some of the other gm 3.8's have? It does not have any white smoke or any oil on the dipstick. It did develope a slight miss a some higher speeds. Would the elbow or bad intake gaskets cause this? Thanks........1SG
Both the elbow and the intake gasket are common issues on these car. If it is right above the water pump it is most likely the elbow. Intake normally leak at the head/intake connection. I think you can replace the elbow by removing the assmembly the belt tensioner mounts to but if you have the time/resourses you should think about just redoing the intake and the elbow. Kill two birds............
Elbow with the water pump removed
