Best Intake Gasket
Old Feb 1, 2013 | 01:56 PM
RedSled99's Avatar
Default Best Intake Gasket
I have a 99 3.8L. Needs a new intake Gasket. Which is the best to buy and do I need the 2nd design with the locating pins? I am going to do the thermostat, valve covers, and the elbows at the same time.
Old Feb 2, 2013 | 06:56 PM
fbodyrs96's Avatar
you need the metal ones 2nd, the first ones are plastic and will fail again. amazon usually sells them for around $50, vs auutozones $90
Old Feb 2, 2013 | 11:06 PM
MKCoconuts's Avatar
Buy a set of Fel-Pro one's and you'll be fine.
Old Feb 4, 2013 | 12:34 AM
fbodyrs96's Avatar
Yeah felpro makes the metal ones also, don't go the all the work to put plastic crap back in there, it's the reason GM changed designs.
Old Mar 7, 2013 | 12:15 PM
RedSled99's Avatar
Got it all fixed. It ended up that one the the elbows was bad plus the gaskets were starting to fail. Thank s for all of your help.
camaroteen82
Apr 6, 2014 11:31 PM
electric avenue 6
Mar 18, 2014 03:36 PM
typeomang
Dec 12, 2010 03:53 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
dcanada53
Mar 5, 2008 06:01 PM
