Installed a CAI and
Old 01-19-2013 | 03:22 PM
|m()d's Avatar
Default Installed a CAI and
makes the car idle around 2000 - 2500? I just pieced one together at local auto parts store it does have a 90 degree elbow at throttle body. am I missing something like the computer needs a chance? Thanks for any input. its a 98 3.8
Old 01-19-2013 | 03:33 PM
BasicConcepts's Avatar
Technical User
you got the maf plugged in?
Old 01-19-2013 | 03:39 PM
|m()d's Avatar
yes. if i unplug it idles great
Old 01-19-2013 | 04:04 PM
I recently put an HAI on my Jeep Liberty, and now it sometimes takes longer for the engine to idle back down to normal when coming to a stop. My thinking (theory) is perhaps my IAT sensor is reading a colder flow of air than it was before and I'm getting a momentary cold engine fast idle. That, or my idle air control picked an awful coincidental time to start effing up! Mine at least comes back down, sounds like yours is remaining high?
Old 01-19-2013 | 04:22 PM
|m()d's Avatar
yes it stays high. just finished giving it a gasket job from the heads on up. Also headers and a cai. i was thinking vacum leak but sheet metal over TB kills engine. sprayed around all gaskets with starting fluid. So i cleaned idle speed did nothing. unplugged maf and it dropped to 750 . So i pulled off cold air from throttle body plugged in maf started it and idled at 1100 has always idled right around 1100
Old 01-19-2013 | 04:59 PM
You mean, you run with the throttle body sucking free air and then it drops?
Old 01-19-2013 | 05:57 PM
|m()d's Avatar
yes free air
Old 01-19-2013 | 06:50 PM
Have you tried hooking the intake tube back up, and removing just the filter to see what it does?
Old 01-19-2013 | 07:07 PM
|m()d's Avatar
no but I will first thing in morning..neighbors will get pissed still open headers. what you thinking as far as filter goes? thanks for your time!
Old 01-19-2013 | 07:30 PM
Not sure yet, brain hasn't jumped that far ahead!
Process of elimination first.
