induction woes
I have developed a crack in that cursed resonator in the stock induction system on my 2001 3.8. I would really like a whisper induction lid and just say to hell with the stock system but we all know how easy those lids are to find. Does anyone have any suggestions?
Post a pic -- you could try some resin repair I imagine...
Search engines, ebay, or call the source:
Whisper Motorsports, 98 & up Camaro & Firebird
Regardless, add an SLP CAI -- you will like the improvement on the highway...
It started back at the connection to the second hose. the thing just folded and caved so I can't seal it off. I have foam in there now to keep things clean but that doesn't sit well with me. It should be fixed right.
It is hard to see and ill get a better pic asap but the light colored object that looks like it doesn't belong is the foam.
I see that foam, but show the hole closer (w/out the foam in it)... Looks like it's in the rubber or the plastic? If plastic, it shouldn't be hard to patch, but the rubber and you probably need a replacement...
