idle
![Cool](https://camaroforums.com/forum/images/icons/icon6.gif)
had the same issue, remove the Idle control sensor, spray with carb cleaner, the pin will be adjusted out, push back in with a back and forth motion, DO NOT TWIST. reinstall using one drop of oil on o-ring. start the car, it will idle about 2500 rpm, dont worry, shut off engine, wait about 10 seconds, restart, should idle around 800-1000 rpm again. this is in the HAYNES MANUAL. about 15 bucks in advanced auto parts. great buy, you'll need it later on, very helpful.
