I think it's a problem
Old Jan 20, 2007 | 01:37 AM
TotalChaos's Avatar
Default I think it's a problem
When am driving normaly say for instance up a hill and i go to speed up slowly, the car acts like it is struggling and it feels like a loss of power. I've already cleaned the injectors, throtle body, new plugs and wires, and fuel filter. Could it be the fuel pump or maybe is it susposed to be like that?
Old Jan 20, 2007 | 01:44 AM
badinfluenceRS's Avatar
Default RE: I think it's a problem
It might be a transmission issue, not downshifting properly and shifting into Overdrive too soon.
I had an oldsmobile that felt like it bogged down often. My first instinct was it wasn't getting fuel properly. However, it ended up it was shifting into OD too soon, and wasn't downshifting properly. Try driving in D and shifting into OD once you get 55+mph
Old Jan 20, 2007 | 01:57 AM
TotalChaos's Avatar
Yup i already do that at around 45. The problem here is around 35 mph. Is there anything else i can do to help this other than changing the gears in the rear end?
Old Jan 20, 2007 | 02:41 AM
does it do it on a flat road...or is it only on hills
Old Jan 20, 2007 | 03:21 AM
jtvyper456's Avatar
Vaccum leak. You've replaced all the other basics, listen to it when you accelerate...sometimes it will whistle or hiss, but at other times it can hide itself...
edit-- read up on this:
http://www.aa1car.com/library/vacleak.htm
Old Jan 22, 2007 | 09:56 PM
usarmyrangrs's Avatar
Ah, sounds identical to my provous problem. Is your computer throwing any codes? Get it checked at an Autozone or Advanced Auto Parts. I kept getting a P0300 code, which is random cylinder misfire. My plug wires had gone up the wazoo, and after getting them replaced (about a 20 minute job), it worked better than ever. I suggest you have it checked. I understand the sound it makes. It's a terible sound even on the slightest grade of a hill, even on the slighest amount of load.
Old Jan 24, 2007 | 10:49 PM
TotalChaos's Avatar
No codes are being thrown. The last code that was given was for a bad O2 sensor. i replaced that. I might try some sea foam and see if that helps.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
