i need help on a partname/where to find it
Old Aug 12, 2009 | 02:56 PM
darnock's Avatar
Default i need help on a partname/where to find it
i'm needing the Tensioner Bracket/idler pulley i believe this is what it is called.
It bolts right above the a/c compressor, and has a stationary pulley.
I've been looking for hours, and I really need your help!
thanks so much
its a for a 98 camaro v6 3.8 s2
Old Aug 12, 2009 | 04:53 PM
Jonny Dubyah's Avatar
any auto store, it should be the idler pully or if its the one hat moves up and down its the tensioner they will be between 12 and 20 bucks..fairly easy to install and remove. if you do it at like orilleys they will probably loan you the tensioner tool thing that makes it even easier..hope that helps, good luck
thewifes68
Nov 13, 2011 07:49 PM
bezerker
Feb 2, 2009 12:23 PM
350rs
Dec 10, 2008 09:07 AM
97rsturbocamaro
Jan 12, 2008 10:11 PM
lgeiger13
Oct 2, 2007 08:56 AM
