I need advice for my car
Old 01-20-2008, 02:46 PM
02StanGT's Avatar
Default RE: I need advice for my car
ORIGINAL: Chappie99
What are you gonna gain by port and polished heads? Better flow? And R/R...give me an idea of price on both and what type of performance your gonna gain.
Not to steal the thread, but in the 5 speed application, what would you recomend for a performance cam replacement?
For your heads P/P will givemore flow, the polishing on the exhaust ports will make them more resistant to carbon build up. Here is a DIY walkthrough of it... http://www.sa-motorsports.com/diyport.aspx
I actually have a spare set of heads I'm working/messing around with. Something I do when I get bored.
High ratio rockers can be had with or without the roller tip. Without, they run about $250 a set, with roller tip about $400. I got mine from Intense Racing. Kit was $399, came with 1.9 roller rockers and new pushrods rocker bolts and pedestals. With 1.9 they recommend a little heavier springs at least 90#. As for the cam, what rear gears do you have? ZZperformance and intense have a variety of cams themselves, as well as other grinds from Comp Cams and such.
sohcnick
03-25-2013 04:03 PM
mynameishank
10-08-2009 06:23 AM
imtico
11-08-2007 12:14 AM
1981camaroz28
10-23-2007 05:44 PM
Harvester
09-09-2007 05:55 AM
Quick Reply: I need advice for my car
