i have a question
Old May 29, 2006 | 05:55 PM
s10man's Avatar
Default i have a question
i have a 94 camaro with 3.4 v6 4-speed auto tranny
will a tranny out of 89 s-10 with a 4.3 4-speed auto
tranny work im told it is a regular 700r4????????????????????????????
Old May 29, 2006 | 06:05 PM
Default RE: i have a question
Your car uses a4l60E transmission, which is computer controlled. The 700R4 is almost the same but it is hydraulically and TV cable controlled. If you install a 700R4 in your car, assumong it is going to bolt up, you will need to change the thorottle body to one that can connect to a TV cable, and then find a proper TV cable. Meanwhile, the PCM will complain that the transmission is gone.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
