how much hp
If you want a hypothesis, that is all you will get here. If you really want to know, take it to a speed shop and get a dyno scan...
ok i have a 95 3.4 camaro and i have done exhaust 80 series and no catt how much you think that added??.. and i was j/w i want too do cold air intake, a mild cam ,a chip/programer and, rear end gears and some kind of ,performance shocks how much hp do you think i will have when done
thanks
jeb
thanks
jeb
What are aluminum heads going to do except fit better and stop warping/leaking? Also, which FWD cars are compatible?
lol, too high.
You can actually get some decent kick out of those 60* V6's, after some work is done on them. For starters, there's aluminum heads that you can get off a fwd for cheap, us 3.8 guys have to drop well over 2k for a set from ZZP.
As with all builds, headers, exhaust, and intake are the base of whatever you do. From there, you can do an aluminum head swap, cam, the list goes on.
http://www.fullthrottlev6.com/forums...ead.php?t=6752
Did you click the link?
