How do you replace the rear shocks on a '94?
I attached the bottom shock bolt first then cut the little tie that holds the shock collapsed and guided the top into the hole where the carpet is. I found that much easier than trying to push up on the bottom of the shock to align the bolt on the bottom.
Just take a look under the car, if you know what a shock looks like then you see where it's bolted at. But it's bolted right next to the spring perches, which are right at the ends of the axle.
So, i may possibly kill someone. The shock snapped off at the place where it connects to the axle. I got the top part out and removed the shock. Now i just need to find a way to get the bolt off where it screws onto the axle. It took a couple hours to get it to break free, but now the back part of it wants to just keep spinning. I grabbed onto it with a vise, but no luck. I didnt expect it to be this much of a ***** lol
#20
NO CUTTING NEEDED, just remove the appropriate screws and quarter panel trim (I think I recall you need to remove the coat hanger to get some off) and you can roll it back.
Don't listen to these hack-job hammer mechanics! ;-)
