High pitched noise
99 camaro V6 standard 120k
After engine is hot the engine emits a high pitched squeel
Its not the alt, idlers,belt, clutch in or out, in gear or not.
Cooling fans seem ok, pulled the fuses one at a time.
increases in intensity with engine speed
Removed the belt and noise is still there
Turn engine off noise does not return right away after restart.
HELP
HELP
HELP
HELP
