hesitant problem
Old Mar 7, 2007 | 06:55 PM
doug's Avatar
Default hesitant problem
Hello i have a 1996 v6 3.8 camaro and it drove perfect and, now today all of a sudden when gasing very hard, it hesitates, and somtimes it makes a sound like it is about to stall. I had put an cold air intake on , and it was located in the wheel well, i dont know if this was touching the bottom of the wheel well and wasnt sucking any air into the engine. I then put the original air filter back on and it is a little better but still hesitates. Any answer???????
Old Mar 7, 2007 | 09:16 PM
Default RE: hesitant problem
Did you put all the sensors back in the right place? Being that it ran good before you adjusted it, you need to go back\k and retrace all your steps till you find out what went wrong.
Old Mar 25, 2007 | 05:31 PM
Ratman's Avatar
Sounds like it's going lean on you. You're bring ing in too much air too fast!
Does the motor recover after you get the stalling sensation?
Old Mar 26, 2007 | 01:33 AM
badinfluenceRS's Avatar
wrong section BTW
Old Mar 26, 2007 | 02:20 PM
Hisss04Cobra's Avatar
You know this is the section for site problems, right?
Old Mar 26, 2007 | 06:12 PM
Moved thread to V6 section.
When you put the CAI in, it requiredfor you to play with the inatake plumbing and the MAF. Make sure you have no air leaks between the MAF and the throttle valve. Also may want to check the MAF out for damage and that it has a good electrical connection.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
