help put another 3800 back on the road wiring question
Old Jun 26, 2011 | 08:19 PM
chadmilliser's Avatar
Default help put another 3800 back on the road wiring question
hello there im new to your forum . I bought a nice v6 1996 camaro thats been sitting since 2001 due to bad head gasket.
well i payed a guy to change the motor .. he cut the main wiring loom that goes from what i think is the ecm? ( passengers side firewall) he cut it and well kinda did not even putting the motor in . I only payed him 200.00 for no big loss but now i have to finish the project. he just did the easy work and left and did not contact me . Just leaves me with a shinny camaro in my driveway with no motor in it .
i connected all the wires back on that harness ( about 20 wires) does it matter if there say like 2 oranges or blacks or so on . or is it just match the colors
also there is a copper ground strap thats on the drivers side down under the fender thats not hooked up ... were do i hook this to . I got the motor back in.AND its not getting any fuel and when i plug a computer into the port it reads no system detected.. were do i go from here.
Old Jul 1, 2011 | 11:43 PM
Katzen's Avatar
tthe copper strap can go any where on the block itself, i had to put mine by the water pump. the strap is needed otherwise the engine wont run at all.... and he never had to cut any wires ..... i did mine and all i did was unplug everything
Old Jul 4, 2011 | 01:47 AM
libertyforall1776's Avatar
Tell us what you need to help you -- do you want schematics -- what specifically?
Here's the wiring of the 80-Pin Engine Controls (PCM) Connectors End Views (all wire colors are listed for ya!):
Document ID# 21229
1996 Chevrolet/Geo Camaro
PCM 80-Way Blue Connector C1 Details
Connector Part Information
Blue PCM Connector C1
Body - 12160549
TPA - 12160569
Terminals - 12084913
Shield - 12160921
Pin
Wire Color
Circuit No.
Function
Component Connector Cavity
DTC(s) Affected
Possible Symptoms From a Faulty Circuit
Lt Blu/Blk
647
18X Reference
ICM C
P0336
Intermittent fault will cause engine miss/cut-out
Blk
630
Camshaft Position PCM Input
ICM F
P0341
Yel
400
VSS High
VSS B
P0502
Speedometer inoperative, late/harsh shifting, chuggle
Dk Grn/Wht
465
Fuel Pump Relay
Fuel Pump Relay 85
None
Stall/no start
Lt Blu/Wht
1747
IAC A High
IAC C
P0506/P0507
High or low idle, stalling
10
Lt Grn/Blk
444
IAC B Low
IAC B
P0506/P0507
11
Lt Blu/Blk
1748
IAC A Low
IAC D
P0506/P0507
12
Lt Grn/Wht
1749
IAC B High
IAC A
P0506/P0507
13
Dk Grn/Wht
817
4K/Mi Speed
Instrument Panel*, SMCC II Cruise Control Module K
None
Speedometer inoperative, Cruise Control inoperative
14
15
Tan
800
Serial Data
DLC 9
P1381
DTC will set when misfire detected
16
Gry
416
5 Volt Reference A
TP Sensor C, MAP Sensor C, and EGR Valve D
P1635, P0101, P0122, P1107, P1122, P1406
Late shifting, incorrect/rough idle, stalling, surging
17
Gry
474
5 Volt Reference B
A/C Refrigerant Pressure Sensor B
P1639, P0530
A/C compressor inoperative
18
19
Pnk
1020
Ignition Feed
Refer to Fuse Block Details in Electrical Diagnosis
P0560
No start
20
Org
1642
Battery Feed
P0560
No start
21
Blk/Wht
451
PCM Ground
Engine block below cyl #2 spark plug
None
Intermittent symptoms
22
Brn
418
TCC PWM Solenoid Driver
Transmission Connector U
P1860
Incorrect/Rough Idle, Cuts-out/Misses
23
24
25
Brn/Wht
419
MIL Driver
Instrument Panel*
P1641
No MIL, MIL ON Steady
26
Dk Blu
1493
2nd Gear Start Light Driver
I/P Cluster
Refer to 4L60-E Automatic Transmission Diagnosis
27
28
Tan/Blk
422
TCC Enable Solenoid Driver
Transmission Connector T
P1864
29
Gry
435
EGR Control
EGR Valve A
P1406, P1635
Incorrect/rough idle, lack of power, chuggle
30
Dk Grn/Wht
428
EVAP Canister Purge Driver
EVAP Canister Purge Solenoid A
P1655, P0441, P1441
Rough idle
31
Dk Blu
473
Fan 2 Driver (High Speed)
High Speed Cooling Fan Relay #2 F5, Series/Parallel Cooling Fan Relay #3 J2
P1652
High Speed Fans inoperative, High Speed Secondary Fan ON all the time, incorrect idle, possible overheating condition
32
Dk Grn
335
Fan 1 Driver (Low Speed)
Low Speed Cooling Fan Relay #1 D2
P1651
Low Speed Fans inoperative, Low Speed Fans ON all the time, incorrect idle, possible overheating condition
33
34
35
Dk Grn/Wht
459
A/C Compressor Clutch Relay Driver
A/C Compressor Relay B5
P1654
Incorrect/rough idle A/C compressor inoperative
36
37
38
39
40
41
42
43
44
Ppl/wht
430
3X Reference
ICM D
P1374
Stalls, sets DTC on restart
45
Red/Blk
453
Reference Low
ICM L
Intermittent Symptoms
46
47
Ppl
401
VSS Low
VSS / TOSS A
P0502
48
49
50
51
52
Tan/Blk
424
Bypass
ICM B
P1361
53
Wht
423
Ignition Control (IC)
ICM A
P1350, P1361
54
Yel
492
MAF Signal
MAF Sensor A
P0101, P0102, P0103
Reduced performance
55
Dk Blu
229
Theft Deterrent Fuel Enable
Body Control Module D8
P1626, P1629
Possible no start
56
Blk
452
Sensor Ground
ECT Sensor A, TP Sensor A, MAP Sensor A, IAT Sensor A, A/C Refrigerant Pressure Sensor A, EGR Valve B, Transmission Connector M
P0108, P0118, P0123, P0530, P0713, P1106, P1115, P1121, P1406
Incorrect/rough idle, lack of power late/harsh shifting, chuggle, A/C compressor inoperative
57
58
59
Ppl
1807
Class 2 Data
DLC 2
None
No scan tool data
60
Blk/Wht
451
PCM Ground
None
61
62
Dk Grn/Wht
762
A/C Request
A/C Control Head*
P0530
A/C Compressor inoperative
63
64
65
66
Ppl
1986
EVAP Vacuum Switch Input
EVAP Canister Purge Vacuum Switch B
P1441, P1442
67
Ppl
420
TCC Brake Switch
TCC Brake Switch A
68
Brn
639
EGR Ignition Filter
P0401, P1406, P0133, P0135, P0141, P0147, P0153, P0155
Fuse blown, EGR Pintle Position error on scan tool varies excessively
69
Gry
48
Clutch Anticipate Switch
Clutch Anticipate Switch C
P0704
Idle flare when clutch is disengaged
70
71
72
73
74
75
Wht
396
Cruise Status
SMCC II Cruise Control Module J
P1554
76
77
78
79
80
Document ID# 21229
Document ID# 21228
PCM 80-Way Clear Connector C2 Details
Clear PCM Connector C2
Body - 12160549
TPA - 1216056A
Shield - 12160921
Pin
Wire Color
Circuit No.
Function
DTC(s) Affected
11
Lt Grn
1222
Shift Solenoid A Driver
Transmission Connector A
P0753
12
Lt Grn
432
Manifold Absolute Pressure Sensor
MAP Sensor B
P0107, P0108, P1106, P1107
Default Manifold Absolute Pressure and BARO
13
Dk Grn
83
Cruise Inhibit Driver
SMCC II Cruise Control Module H
P1662
14
15
16
Red
25
Generator Lamp Driver
Instrument Panel Cluster
P1663
No generator lamp, generator lamp ON
17
Yel/Blk
1223
Shift Solenoid B Driver
Transmission Connector B
P0758
18
Wht
687
3-2 Control Solenoid Driver
Transmission Connector S
P1886
19
20
Lt Blu/Wht
1229
Pressure Control Solenoid Low
Transmission Connector D
P0748
21
Blk/Wht
451
PCM Ground
None
22
Pnk/Blk
1746
Injector Cylinder 3
Injector Connector B
P1200, P0300
Incorrect/Rough Idle, Missing, Flashing MIL
23
24
Lt Grn/Blk
1745
Injector Cylinder 2
Injector #2 B
P1200, P0300
25
26
Blk
1744
Injector Cylinder 1
Injector #1 B
P1200, P0300
27
Pnk
1224
Transmission Range A
Transmission Connector N
P1810
28
Yel/Blk
846
Injector Cylinder 6
Injector #6 B
P1200, P0300
29
Dk Blu
1225
Transmission Range B
Transmission Connector R
P1810
30
Blk/Wht
845
Injector Cylinder 5
Injector #5 B
P1200, P0300
31
Red
1226
Transmission Range C
Transmission Connector P
P1810
32
Lt Blu/Blk
844
Injector Cylinder 4
Injector #4 B
P1200, P0300
33
Lt Blu
533
Shift Select Switch Input
Shift Select Switch
34
35
Brn
225
Generator Control
Generator L
P0560
Charging system inoperative, Generator lamp commanded ON
36
37
38
39
40
41
42
43
44
45
Ppl
1666
Bank 2 HO2S 1 Signal
Bn2 HO2S 1 A
P0151, P0152, P0154
Open Loop Fuel Control
46
Tan
1667
Bank 2 HO2S 1 Low
Bn2 HO2S 1 B
P0154
47
Dk Blu
1980
Bank 1 HO2S 3 Signal
Bn 1 HO2S 3 A
P0143, P0144, P0146
48
Gry
1981
Bank 1 HO2S 3 Low
Bn 1 HO2S 3 B
P0143, P0146
49
Ppl/Wht
1665
Bank 1 HO2S 1 Signal
Bn 1 HO2S 1 A
P0131, P0132, P0134
Open loop fuel control, incorrect/rough idle
50
Tan/Wht
1653
Bank 1 HO2S 1 Low
Bn 1 HO2S 1 B
P0134
51
Tan
472
Intake Air Temperature Sensor
IAT Sensor B
P0112, P0113, P1111, P1112
52
Yel
410
Engine Coolant Temperature Sensor
ECT Sensor B
P0117, P0118, P1114, P1115
Hard Start, Incorrect/Rough Idle, Cooling Fans Commanded On
53
Dk Blu
417
Throttle Position Sensor
TP Sensor B
P0122, P0123, P1121, P1122
Late/Harsh Shifting, TPS Default
54
Dk Blu
1978
Bank 1 HO2S 2 Signal
Bn1 HO2S 2 Connector A
P0137, P0138, P0140
55
Gry
1979
Bank 1 HO2S 2 Low
Bn 1 HO2S 2 Connector B
P0137, P0140
56
57
58
59
60
Blk/Wht
451
PCM Ground
None
61
Red/Blk
1228
Pressure Control Solenoid High
Transmission Connector C
P0748
62
63
Dk Blu
496
Bank 1 Knock Sensor
Bank 1 Knock Sensor
P0327
Default Knock Retard commanded
64
Lt Blu
1876
Bank 2 Knock Sensor
Bank 2 Knock Sensor
P0327
65
Brn
1456
EGR Pintle Position
EGR Valve C
P1406
Incorrect/Rough Idle, Cuts-out/Misses, Chuggles
66
67
68
69
70
71
Yel/Blk
1227
Transaxle Fluid Temperature Sensor
Transmission Connector L
P0712, P0713
72
73
Red/Blk
380
A/C Refrigerant Pressure Sensor C
P0530
A/C Compressor Inoperative
74
75
76
77
78
79
80
Document ID# 21228
rsheele68cam
Dec 28, 2012 09:48 PM
Andrew Bean
Apr 30, 2012 05:53 PM
talikaluvr
May 25, 2009 11:59 PM
Allamericantc
May 7, 2009 01:31 AM
AV95Z
Dec 31, 2007 03:37 PM
