HELP PLEASE 95 3.4 V6 WONT START
RE: HELP PLEASE 95 3.4 V6 WONT START
Idealproductz
Update on my 3.4 ,just got it running
turned out when we tested the coil packs we got them backwards when we put them back on
swaped the 1 and 4 to the 2 and 5 side and runs fine now
our original problem was the crank sensor and PCM and blown ignition fuse
Thanks Z28 Pete for the coil lay out in the other post
it got my mistake straightened out
Check the cam and two crank sensors like pete said and fuel pressure
the fuel pressure test port is on top of the fuel rail by the regulator it will be between 41 to 47 lbs, mine was about 44.
Check the oil and see if it smells like gas you can have a leaking regulator diaphram
we replaced ours and it was about to start leaking , the rubber will start cracking
it is a easy fix i think it had 6 torx bit screws on top .
