HELP!!!! MULTIPLE MISFIRE
Old Apr 18, 2006 | 05:28 PM
briggette's Avatar
Default HELP!!!! MULTIPLE MISFIRE
Any help would be greatly appreciated!
My car is a 96. The car started acting up so my husband checked the codes. We are getting a multiple misfire. The car has new plugs and we just replaced the ignition coil pack. Any ideas? I think he is changing the plug wires tonight. So I am just wondering if anyone has had a similar problem and how they resolved it
Old Apr 18, 2006 | 06:28 PM
SickSickSick's Avatar
Default RE: HELP!!!! MULTIPLE MISFIRE
The Pickup Coil May Be Loosing Ground. Check To See If The Tape That Covers The Coil Is Burned. If It Is Replace It. You Have To Pull The Distributor, Remove The Bottom Gear And Slide The Shaft Out. A Ring Type Keeper Holds The Pickup Coil In Place. While Your That Far In To It You May As Well Have The Ignition Module Checked As Well. Sick
Old Apr 21, 2006 | 02:20 AM
After you changed the plug wires and still getting misfires, there is good chance the ignition module, sitting under the coil pack is sick, or the fuel delivery may be off. Check the fuel pressure at the fuel rail, if OK then check that all the injectors are firing
walker61
Nov 29, 2014 11:01 AM
1badramz28
Apr 30, 2009 04:55 PM
camarofreak1990
Sep 25, 2008 04:04 PM
golfballs
Apr 8, 2007 08:30 PM
