help with 97 3.8L tranny
Old Nov 1, 2007 | 05:43 PM
greencam97's Avatar
Default help with 97 3.8L tranny
I bought my 97 Camaro 3.8L used with 90k miles on it four years ago, it ran great and only had a few aestetical issues, but now it has reached 113k miles and the throttle response has gone to hell in a handbasket, when its wide open it will be sluggish when changing gears, and when it finally does switch to third gear the check engine light will come on. Basically I think it needs a new torque converter because now im in college and about two months ago I let my buddy drive it home, he dropped it into neutral, redlined it, and threw it into first... I nearly killed him when he did it, and since then it hasnt been the same. Its a 4 speed auto, if you have any idea what it might be please respond.
Old Nov 1, 2007 | 05:59 PM
libertyforall1776's Avatar
Default RE: help with 97 3.8L tranny
Some "buddy"... :-(
Old Nov 1, 2007 | 06:30 PM
greencam97's Avatar
No joke.. it was a grinding noise that no car should ever make. Im still trying to get ahold of his boost controller and jack it up to about 60psi and watch his engine explode..
Old Nov 10, 2007 | 03:01 PM
97rsturbocamaro's Avatar
check your trans fuild levels and maybe change your filter if that doesnt help take it to a pro and get it checked out... may be a TQ or may need a new tranny the 4L60E in my car shifts hard into second but thats because it needs to be flushed i suppose...
Old Nov 11, 2007 | 12:22 PM
Use Dexron 6, not Dexron 4...
Old Nov 11, 2007 | 01:52 PM
ninetysixyenko's Avatar
my friend does that **** all the friggan time to his neon, and he's replaced tranny 3x, and had to do engine mounts 4 or 5 times, keeps breaking them and what not.
Old Nov 15, 2007 | 09:19 AM
greencam97's Avatar
I changed my tranny and engine oil with high mileage synthetic (about 1500 miles early for the engine) and replaced all the filters and there has been alot less hesitation and jumpiness. My only guess is the engine is spinning more easily. Time will only tell if its a temp fix. Thanks guys.
Old Nov 15, 2007 | 11:36 AM
So did you go with the Dexron 6? If so, you should have added protection... especially so if you did a full flush...
Old Nov 15, 2007 | 05:44 PM
greencam97's Avatar
Yeah I splurged a bit on the Dex 6, seems to be running fine so far... (Knock on wood)
Old Nov 15, 2007 | 06:07 PM
Did ya do a full flush, or just drop the pan?
