Help !!!! 92 RS 3.1 Wont Start
Old Jan 4, 2006 | 10:27 PM
fjm280z's Avatar
Default Help !!!! 92 RS 3.1 Wont Start
I have a 92 RS 3.1. Was running fine up until two nights ago, when it started fine, idled fine ran fine for about 5 minutes then It stalled and wouldnt start again. I had no spark. Gas pressure was fine at the schrader valve at the top of the engine.
Next day, I went back to diagnose problem and tried to start the car and it started right up, idled fine and ran for about 2 minutes then died. She cranked strong but wouldnt turn over. I check the valve again for gas - pressure was fine - no spark at plugs, cap or coil.
I changed the ignition coil -no start. I changed the pickup coil, distrubutor cap an rotor. She started ran for a few minutes and died again. check for spark - no spark.
I dont have a code reader for ECU hook up to see if any codes are popping up. Has anyone encountered a similar problem and what was the problem? Any Help would be greatly appreciated !!!!!!
Thanks,
Frank
Old Jan 5, 2006 | 12:08 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Help !!!! 92 RS 3.1 Wont Start
you dont need a code reader for that year....cant you flash the ecm?
Old Jan 5, 2006 | 02:43 AM
fjm280z's Avatar
It did it again tonight - started ran great for about 5 minutes like nothing was wrong, then bang she dies !!!
I dont know how to flash the ecm !!! How do you do that and what does flashing the ecm do?
This is a really weird problem.
Old Jan 5, 2006 | 03:48 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
itll give you a code by flashing your check engine light. if you have a haynes manual, it will give the procedure, usually under computer, or trouble codes
bascially you ground out 2 prongs on your datalink cable under the dash and turn the car to on but dont start it. the first code will flash 3 times
one blink, pause, two blinks this is code 12, meaning diagnostic mode
after that, any stored trouble codes will flash for example, four blinks, pause, 2 blinks would be code 42
Slundy12
Dec 11, 2011 07:57 PM
Luz Hernandez
Feb 26, 2011 09:17 PM
mjstempky
Feb 19, 2011 01:17 PM
jpkz94
Jan 21, 2011 01:47 PM
89Rally
May 3, 2007 01:49 AM
