Help!!!
Old Feb 5, 2013 | 06:41 PM
  #21
yes, should be in the exhaust between the catyletic converter and engine.
Old Feb 5, 2013 | 09:29 PM
  #22
jml2002's Avatar
I have a 3.8 v6. I see one on each side towards the back. So unplug both when car is on?. Wat am I looking for it to do.
Old Feb 6, 2013 | 07:06 AM
  #23
better yet get the ohm meter out and test the 02 system. Product & HowTo Info | | | TEST | AutoZone.com
test maf as well
https://camaroforums.com/forum/93-02...ing-maf-63856/
Old Feb 6, 2013 | 01:26 PM
  #24
and the map. copied from another site
When you turn the key to "on" (engine off) the MAP senor should read the local barometric pressure. If you live at sea level, you will see close to 5V between the green wire and the black wire. If you are above 1,000-ft elevation, you will get lower voltage as altitude increases. When you start the engine, at idle, closed throttle, with the stock cam, you should see about 1/3 of the barometric pressure. A typical reading would be about 1.3 to 1.4V.
And again you have to make sure you have 5V reference between the gray wire and the black wire.
Old Feb 6, 2013 | 09:28 PM
  #25
jml2002's Avatar
Is map called something else on 3.8. The book only talks about it on 3.4 and 5.7
Old Feb 6, 2013 | 09:31 PM
  #26
jml2002's Avatar
Oh wait here it is.
Old Feb 7, 2013 | 06:09 AM
  #27
jml2002's Avatar
On the 2002 3.8 v6 where is the MAP
Old Feb 7, 2013 | 08:56 PM
  #28
jml2002's Avatar
Should I just buy another throttle body.
Old Feb 8, 2013 | 11:10 PM
  #29
jml2002's Avatar
I started my car today and the check engine light came on finally. Codes P1120, P1220, P1221, and P1516 show up.
Old Feb 9, 2013 | 07:15 PM
  #30
jml2002's Avatar
Those first 3 codes are throttle position sensor codes and then throttle actuator control throttle position performance. Are there 2 tps sensor inside the throttle body somewhere? Sounds like I should just buy another throttle body unit. Unless someone disagrees....
