help!!!
Old Oct 19, 2005 | 07:04 PM
Evo_Lution's Avatar
Default help!!!
Yesterday we were messing around around with a 1998 camaro rs and all the sudden the car wouldnt go into gear and it started making a grinding noise so we looked underneth and the driveshaft was spining fine but there is this gold thing it connects to before it goes to the rear end, and the drivshaft was just spinning inside it. Can someone tell me what it is and how i fix it?
Old Oct 19, 2005 | 10:48 PM
camero98female's Avatar
Default RE: help!!!
could it possibly be the gear linkage from the transmission to the rearend?
Old Oct 19, 2005 | 11:18 PM
Evo_Lution's Avatar
Default RE: help!!!
I dont know what it is, It does connect them though. It might be a coupler or something but so you know how much it is to replace and what it is called
Old Oct 20, 2005 | 01:31 AM
Default RE: help!!!
It is a little difficult to figure out what you are trying to tell us, but if your driveshaft is spinning and the car is not moving, you either broke one of the driveshafts, a U joint, or your rear end gears. The RS has a two pece driveshaft with a support bearing in betwenn the two parts.
Old Oct 20, 2005 | 02:16 AM
Evo_Lution's Avatar
Default RE: help!!!
well ok the front part of the driveshaft is spinning but the back part is not spinning, so is that the "support bearing" If so Can you buy that or do you have to buy a new driveshaft.
Old Oct 20, 2005 | 12:47 PM
Default RE: help!!!
From what you are telling me you broke something between the front & rear drive shaft. In any case, you will have to pull the driveshafts down & see what is going on. Most likely a uneversal joint let go. The bearing itself is only there to hold the driveshafts in place.
Old Oct 20, 2005 | 03:40 PM
Evo_Lution's Avatar
Default RE: help!!!
ok thanks for the help
Old Oct 20, 2005 | 07:28 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: help!!!
so was it the universal or not?
Old Oct 20, 2005 | 07:54 PM
Evo_Lution's Avatar
Default RE: help!!!
Dont know yet but it looks like it could be, i have to find a way to get it to a place where i can lift it.
Old Oct 21, 2005 | 12:14 AM
02StanGT's Avatar
Default RE: help!!!
98 didn't make a RS. Some had the body kit, but were not badged as an RS. 97 was the last year.
