Heater not working.
Old Jan 13, 2019 | 10:54 AM
Driver50x's Avatar
Default Heater not working.
The heater had been working fine. Then I changed my intake manifold gasket. Everything else is good, but my heater no longer works. I have driven it about 200 miles, and I have checked the coolant level multiple times. The upper radiator hose gets hot after driving, but the heater hoses feel pretty cool. The weird thing is, if I jack up the front end and run it, the heater will start working, but the next time I drive it it will not work again.
Its a 1995 Camaro with a 3.4
Any ideas? Thanks in advance.
Old Jan 13, 2019 | 12:20 PM
Might be air in the system that needs bled out, maybe try back flushing the heater core could be something plugging it.
Old Jan 13, 2019 | 01:48 PM
Driver50x's Avatar
I tried flushing the heater core both ways. It did not make any difference.
Old Jan 15, 2019 | 07:00 AM
woh that is weird. does sound like air, did you try bleading the air when front was up.
Old Jan 15, 2019 | 12:26 PM
Driver50x's Avatar
Update—
I backflushed the heater core again, this time using a LOT of pressure from the garden hose. A BUNCH of nasty looking stuff came out of it. I think the previous owner may have put stop leak in it at some point. I’m guessing the core is still 3/4 plugged up, but the heater is now working, at least good enough for a Florida car! ��
pcarollo
Nov 8, 2017 10:57 PM
TheGrimReaper73
Nov 3, 2008 04:13 PM
z28nate
Oct 12, 2007 08:50 PM
95Z28pit
Sep 18, 2007 07:01 PM
wesgmc
82-92 V6 Tech
Jun 27, 2007 08:53 AM
